The file itself is not the problem. In fact, it sounds just fine to be incorporated into other my sound mod.
So I think, the file name is wrong? Or failed to repak? :confused:
i repacked it correctly and the file is named correctly afaik.
Let's see what tduchicken says if he checks it out.
Well I downloaded the file and listened to it... Seems allright...
But I will explain it to you how to make a Soundmod working:
1. Take a root file (which has easy basics (at least at the beginning)) such as skyline_high.bnk
2. Unpack this bnk and look at the sound files (skyline_high.bnk/Build/R8_V10).
3. There you will find tons of sound files, but just (again for beginning) concentrate on ST_R8_Startup (startup), ST_clk_onhigh (revs), ST_R8_exhaust (exhaust rumble or turbos) AND ST_R8_idle (Idle, low revs)
4. Listen to the original (at 3. named) sound files
5. Rename your edited sound files to ST_R8_Startup etc. and paste them into the skyline_high.bnk folder (skyline_high.bnk/Build/R8_V10)
6. Repack skyline_high.bnk with the .bnk file you want to replace. For example skyline_high.bnk --> xkr_high.bnk etc.
7. Enjoy!
I hope this little instruction helped :)
Greets
7. Enjoy!
Greets
Yes I know how to make a soundfile, that's quite obvious as I have stated.
I'm asking why the conversion file isn't working.
