[FIX] Game crashing after 1 hour
Posted (edited)
Pretty much exactly an hour in the game crashes no matter what I'm going. Game is running fine and then it just closes. Game starts back up fine. Running the game unpacked with a NVIDIA GeForce GTX 1050.
Edited by Nivracer
Hi Nivracer,
Interesting issue. Normally issues like this happen with RTX cars, but you're on a 1050 so it cannot be that.
Try disabling any game overlay you may have running in the background, those can often solve weird issues like this.
Try this (assuming you have 64-bit Windows).
Go to the folder when TDU2 is installed. Copy testdrive2.exe and paste in the same location to create a backup.
Then download this 4gb_patch.zip file, extract it, and run it.  It will ask you to select an executable to patch.  Select your original testdrive2.exe file (not the backup).  After the successful message, try playing TDU2 again and note if the crashing goes away or reduces in frequency.  Then report back here with the results.
Note - if you are unable to download this attachment, please make sure you have joined the TDU World club on these forums first.
Go to the folder when TDU2 is installed. Copy tesdrive2.exe and paste in the same location to create a backup.
Then download this 4gb_patch.zip file, extract it, and run it.  It will ask you to select an executable to patch.  Select your original tesudrive2.exe file (not the backup).  After the successful message, try playing TDU2 again and note it the crashing goes away or reduces in frequency.  Then report back here with the results.
Expand
Awesome! Will try this out
Expand
This worked. Put quite a few hours in today with no crashes. Thanks!
  • Nivracer changed the title to Game Crash after 1 hour [Fixed]
  • Aquarious changed the title to [FIX] Game crashing after 1 hour
  • Aquarious pinned this topic
