I was driving to day and i get soo mad on the automatic gearbox when it switches on the highest rpm so i thought that tdu 2 should have a gearbox that you can switch example when you drive just for fun if you want you could switch it to normal mode then it will change gear on lower rpm and when your in a race you switch it to race mode then it will switch on higher rpm.
I know this is not gonna happen but i will give it a try
Greetings, Christoffer
I believe this happens in GTA IV. If you listen carefully, when you only apply a tiny amount of acceleration, the gearbox goes into a higher gear. If you then suddenly accelerate hard, then there is a noticeable pause, the car kicks down and you go...
Yeah, GTA does it. That's one of the reasons I love that game.
Yeah, I've often thought about that. I tried to kind of make it by making the clutch on the G25 Gear-Up for really smooth shifting that would feel the most like a proper automatic, but it wasn't that great :(.
