Slight Problem with Launching...
CoolCarFan
are you using the universal launcher? are all your big/map files moved to a different folder? did you try starting the game in between unpacking and adding a mod? if you did what a happened.. if you didnt, why not ?
Give us as much info as you can about what you did . the more info we get the easier it will be to help you out.
I have the same problem.
I am using the universal launcher, using the latest version. I also unpacked with the latest unpacker. Never i aborted the unpacker, however in the beginning of unpacking it says four times something about a duplicated file <-- I think that's the problem but i can't find a way to solve this....
It happens when no other car is added or modified and the game runs if I put back the original .BIG and .MAP - files. I haven't tried yet if change a car would solve this problem, but I think it won't.
  • 9 months later...
