  • 5 months later...
I've already found a way to solve this problem ;) select the whole sound sample, copy and paste at the end of it (to make it double), but select the Reverse command (from Effects) for the "new" sample (for the "new" half), the sound won't change, it would change only if you use the other similar effect named "Invert" (don't confuse the Reverse effect with the Invert effect, both have the same meaning, but just apparently)
[ATTACH]19935[/ATTACH]
don't forget to verify the Resulted Sample by importing it, to see if there is any gap at the end or at the beginning of the sound
for me this works every time, but I remember that this didn't worked some time ago (but I think that I am wrong, or : maybe now I have the right Preferences that this procedure to work, but I think I just remember wrong)
Can someone help the both of us? I'm having this problem too.
