Hello!
There's been something about trying to make sound mods for certain cars that is really starting to tick me off. The current one i'm working on is the AC Cobra 427. It sounds nothing like the loops i used.
The sound sounds like it uses one loop, pitched up. It doesn't use the aggressive onhigh sound, instead it seems very dull and synthetic, like using the onidle or onlow sound to create the whole sound while pitching it up. The idle sounds normal, but everything else is screwed up. I can record what happens to an audio file if needed.
Will someone please help me? Thanks in advance.
EDIT: FIXED!
Solution: Make ST_fordgt_onhigh.wav & ST_stratos _onhigh.wav (yes, there is a space) silent. Now it sounds much better.
You'll need to be more explanatory about what problem(s) you are experiencing for people to look to help you. As I can guarantee the first question by anyone will be that.
