Midnight Club: Los Angeles :: Custom Controls!
Here is my custom controller layout if anyone is finding it hard to set one up nicely. =]
NOTE: This is for manual shift! Xbox 360.
Steering - Left Stick
Gas/Throttle - Right Trigger
Brake/Reverse - Left Trigger
Shift Up - B
Shift Down - X
Handbrake - A
Weight Transfer - Left Button (Above Trigger)
Nitro - Right Button (Above Trigger)
Headlights - D-Pad Up
Horn - Left Stick Push (Push the stick down)
Special Ability - D-Pad Left
Change Camera View - D-Pad Right
Overhead Map - D-Pad Down
Look Back - Y
Look Left - Push Left on the Right Stick
Look Right - Push Right on the Right Stick
Zoom in (On cockpit view) - Push Up on the Right Stick
Convertible Top Up/Down - Push Down (NOT Click) on the Right Stick
Hope that helps someone. =]
Post your own up too if you like. =]
Custom Controls
Gears: Manual
Steer: Left Stick
Acceleration: Right Trigger
Brake/Reverse: Left Trigger
Shift Up: B
Shift Down: X
Handbrake: Right Button
Weight Transfer: Left Button
Nitro: Click Right Stick
Headlights: A
Horn: Left Stick Click
Special Ability: D-Pad Left
Change Camera: Y
Overhead Map: D-Pad Up
Next Track: D-Pad Right
Look Back: Right Stick Down
Look Left: Right Stick Left
Look Right: Right Stick Right
Look Up: [bLANK]
Convertible Roofs: D-Pad Down
Copied Diablo's post, but with my edited controls =)
Gears: Automatic
Steer: Left Stick
Shift Up: N/A
Shift Down: N/A
Handbrake: Y
Nitro: X
Headlights: A
Special Ability: Right Stick Click
Change Camera: Right Button
Look Up: Right Stick Forward
Convertible Roofs: B
I made a mix between MC3's and TDU's controlls, In MC3 the brakes were both Square and Circle, so I changed the B into that, also in TDU I didn't use manual so I didn't need them =)
Gears: Manual
Steer: Left Analog
Acceleration: R2
Brake/Reverse: L2
Shift Up: R1
Shift Down: L1
Handbrake: X
Weight Transfer: Up Arrow
Nitro: R3
Headlights: Down Arrow
Horn: Circle
Special Ability: L3
Change Camera: Triangle
Overhead Map: N/A
Next Track: Right Arrow
Look Back: Right Analog Down
Look Left: Right Analog Left
Look Right: Right Analog Right
Look Up: Right Analog Up
Convertible Roofs: Square
