hi guys
i thought about a new engine sound for the C63 and so i made one.
it sounds quite good in my opinion but could of course be better : )
but still i hope you will like it : )
VERSION 2
Ignition time 1,2
Preview V2
DOWNLOAD V2:
http://www.filefront.com/17130787/Mercedes-Benz%20C63%20AMG%20Sound%20Mod%20V2.zip
http://www.mediafire.com/?ztg9v4djawinys7
VERSION 3
Ignition time 2,4
DOWNLOAD V3:
http://depositfiles.com/files/zaz4azztf
for 7 gears use this settings please : )
I can't view the video for some reasons. It always gets stuck when you start the car.
hm dont know it works fine for me : |
tried another browser?
the sound is waaaaaay to high...
what do you mean with to high? : )
It's good but need some little improvements.
There's is a Mercedes Factory around here, these things are being tested there and I heard the real one a couple of times.
So here's my suggestion, when rpm is idle (right after starting the car) the sound must be a bit lighter and not soo loud.
Mid rpm should be a bit darker/deeper and the volume is alright
And at very high rpm this car sounds more agressive and louder.
I hope I could explain myself :D
well im trying another sound samples right now which sound a bit better in my opinion.
it is more similar to the real sound at onboard recordings.
and by the way the idle sound is fixed and i found an excellent starter sound : )
will release v2 soon ; )
thanks for your comments and suggestions!
The throatyness is there, it's just that it doesn't have the same bass and deep sound as that of the C63.
Hopefully there'd be a deeper sound soon.
Great sound! Fits the C63 very well. Though I do have a few questions.
1) Is it really that silent from 1000-1500 rpm? V1 wasn't that quiet.
2) What is the max rpm for your sound? I feel as if it starts to sound flat as I reach 7000. I'm thinking it has 6750 as its limit, as the CLK55 has originally a 6750 redline? If that's the case, might I suggest you to increase the rev limit of your sound to 7200 rpm? There are quite a lot who use custom physics (like me) and have their C63 revving all the way to its real-life 7200 rpm redline. It's just quite disconcerting when it flattens out before the actual redline, and it actually makes me wary of revving up to redline before shifting as it just sounds awful. :(
