For your first sound mod is incredibly great (seriously)
I mean you didnt only limit yourself to change one sample of the engine
you were carefull with everything (samples treatment) and even changed the tire skid sounds ;)
Clean transitions (you got to work on the pitch only a bit more)... and most of all it sounds like a bmw ... you were carefull to notice that a car on lows (rpms) sounds completly different from high (rpms)....and thats what most of sound modders forget about and its very important
Great stuff really ...again if this is your first sound you did a wonderfull job .... keep them coming if possible +rep
I am honored to get your comment.
I will improve this with attention to the things that you pointed out.
  • 3 months later...
  • 5 weeks later...
  binbow said:
And then... I feel like was the same answer even before to :D
Oops ... was it by me? :eek:
That version 1.43 I already tried, without suxxess, if I'm right. But I will try again.
Perhaps it didn't work ealier, because I got an older/modified testdrive2.exe at that moment. :D
Thank you for reposting thought :)
EDIT:
Well, it works :D
My fault was, that I put the ingame radio off AND set the radio volume to zero.
Increasing the volume brought up indicator sound. :)
  franks said:
Well, it works :D
Ah..that's why. Anyway, congratulations! :)
