I love the sound. But, if you could make the onhigh file the same as the onmid file but at a higher pitch, it would be PERFECT. the same goes to offhigh. make it just like offmid, but with higher pitch. That would make your sound no.1 :nuts:
Guest April Swift
umm i loved it thank you so much
  • 3 months later...
  Urban said:
Meh...the high revs are from an Atari original sound...not sure which one...maybe the Murcielago's.:rolleyes:
The guess is an incorrect answer. :)
It is an obviously different sound.
I love the startup and idling, I've heard a 430 several times and it sounds exactly like this. But the high-range isn't really realistic.
I've made two videos about F430's, maybe you can do something with it.
[TUBE]<object width="425" height="344"><param name="movie" value="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/TUBE]
At the first vid you can clearly hear the high-range.:p
