odd because it is a brand new monitor
@Acid
Acer Aspire M3970
Windows 7 home premium 64 bit
6GB DDR3 Memory (Ram)
AMD Raedon HD 6570 1 GB (1024 MB)
Intel Core I5 Processor 2300
1.5 TB hard drive
Blu Ray/ Super Multi Combo drive
as I said, it sounds as though your resolution is set wrong for the monitor.
Despite it being a new one, it could be in a different aspect ratio - so your monitor can't read it.
It's a very common thing in my work where customers bring their computers in and our cheap-ass monitors can't read the signal from the PC. We have to reboot in VGA mode (640x480 :( ) to change the resolution to something better.
If you can, plug your old monitor back in, change the resolution to 800x600, turn the PC off, plug the new monitor in and all shall be well.
you can also launch TDU with changing the command line :
add the -w switch to executable command in shortcut
TestDriveUnlimited.exe -w
game will run in 1280x720 - will allow you to start and set a correct resolution. Save it then quit, finally start the game without the -w :)
There are useful switchs, main issue is I haven't been able to combine them :
- fps : display fps
- pos : gives coordinates (kinda debug mode)
- w : windowed mode
maybe there are others ...
Ok i ran it in 640x480 mode and changed the resolution, then ran it in normal mode. I get the floating box during the intro but as soon as I get to the menu it's fine. Thanks for the help guys :)
  • 8 years later...
Posted (edited)
Sorry for comming late to this party; but I (still) have this problem, being it on WINDOWS 10.
Just went through a driver removal an install with DDU but still I get the "input not supported" box.
I'm booting via the Universal Launcher. The game does run in the background (I can hear the sound) but that's it.
Any tips or tricks?
*** EDIT ***
The problem was in the save game.
When I cleared the folder and booted, everything worked like a charm!
Edited by Little_ghost
There's no universal launcher for TDU, would this be project paradise launcher? there's an option to run game windowed. That would be worth the try.
If game is TDU2, alt+enter keyboard shortcut switches to windowed mode.
