New Aston Martin DB9 Sound Mod v2
saladine1
My new DB9 sound.
Experimenting with new technique so it may sound a little weird.
EDIT: I recorded from further back of the car.
The custom exhaust note and rumble of the v12 is...louder. Turn up the bass of your sound system.
Compare the two different versions in my Youtube
Videos.
Aston Martin DB9- http://www.sendspace.com/file/lv222i
These samples were recorded from a car that belongs to my boss.
Admittedly, he had some work done to the exhaust and some internal work, raising the rpm range limit.
That's why it sounds higher pitched than normal.
I also recorded from the front of the car, where I would usually record from further back.
Also, the original sample slots offered only 2 on/off samples reducing the natural sound of rising rpms.
I must say though, full ball in this thing is pure magic!
Hey, what did u used for recording?
I got my Cannon 10 Megapixels (new model so I think it should record well)
but when I record NFS UC Sound I found that it has a litmit, and if I just simply raised the volume in Audacity the sounds becomes weird,
and very high ptched, plz tell me what u use to record, my webcam is even worse.
Edit: o and BTW the sound mod is Brilliant!!! +Rep!
  • 11 months later...
