  • Replies 88
A lot of answers in one post :P
  zo6dude said:
Maybe the 2010 Camaro SS sound?. Tool made one awhile back but hasn't made the new one from Shift yet
When Camaro from Shift will be done, I'll start thinking about it.
  "tdu ggas said:
Hey, can you convert a new sound by Shift?
Audi S3 sound!
Thanks!
Exactly the same as higher.
  "Saleen_S7 said:
a suggestion, after you finish the gt3 rs sound, why not make the gallardo sound, because we don't have a great sound for it
Again, same.
  camryt said:
My proposition for a new sound mod is Lexus LFA's V10 roar. The car has been already released, you just forgot about this one, I guess.
First good proposal, cause it's made already (I mean car model from Shift). Goes up in my queue to second place. And first is...
  matt1314 said:
We have only a "LP560" Gallardo sound, but not of the original Gallardo. My suggestion would be to convert the sound for Tool's Ford Escort RS.
Yes, Escort RS Cosworth is first. Cause I've started it, but I was just lazy and haven't finished. Unfortunately, next week I'll probably busy, so maybe next weekend. You'll certainly get it before Christmas, though ;)
  Bimmer said:
when you gonna do the cayman sound mate? :)
cos im sure in SHIFT it's a little different to the 911 sounds
correct me if i'm wrong though
  Cada said:
How are you actually converting the sounds? I extracted the sounds with the Extractor ( http://www.nfscars.net/file/view/shift/10034.aspx ), but every application I have just fails in every epic way possible to open the damn audio files.
Magic. :) If I'd discovered it without asking anyone, why should I share this information to others? Noone helped me, so really, keep on trying. I can tell you something, however - you can open it with totally freeware software, don't need any very advanced and expensive stuff.
That's for it now. :p
Whats up, I have a little challenge for you:p:p Can you convert Honda Civic Si sound from NFS Shift or Pro Street?
It should be easy for you:thumbsup::thumbsup:
Thank you:cool::cool:
Guest turbo lag
Can I request the Impreza STI sound from Shift? Tool's had 2 mods done, albeit quite a long time ago. They're still pretty damn good quality though compared to some other mods I've seen. If you can do this, thank you.
As my grandfather said: If you don´t know something, ask everyone. If you know something, share it with noone. I know its offtopic but it´s EPIC! :D
And one more thing please, will you do a soundmod for Tools forthcoming Novitec 599? I know there are no Shift samples for that car so I guess it is hard to do, but a correct sound for that car would be great.
P.S: You are my favourite sound creator. Keep it up&thanks.;)
  Urban said:
Could you try to make a new Turbocharger sound (i think its in commoncar.bnk) because TDU one sounds like a vacuum cleaner.
Pretty please! xD
Had to answer this one: Turbocharger is actually sucking air like a vacuum cleaner so it's really not strange that they sound similiar :D
Is it sucking or blowing air??:confused:....sucking the air makes no sense.
Anyway it doesn't sound like the real thing. If u are not interested in modding it there's no problem. :)
If it's blowing air, it must suck it earlier, it doesn't produce it by itself. Anyway, I currently have unninstalled TDU from computer, because I have enough of it for now, must have break. Should be back in few months. ;)
Bad 2 hear that. Now we will have new cars released with no sound mods. :(
I still wonder if Skepsis or saladine would show themselves again.
I hope a decent sound modder will pop up soon cause the next months will be sad if fifomaniak takes a break.
Turbos...
A turbocharger has two sides the compressor(cold side) and the turbine/turbine housing(hot side) exhaust gas spins the turbine impeller wheel. the impeller wheel is attached to a shaft which turns the compressor wheel. the compressor wheel sucks in air through the intake and blows it out, usually into some sort of intercooler. so it both sucks and blows...
