Hello, I'm back. I missed TDU, I just needed a break from it for a while, but now I'm coming with new energy and experience. So I've redone the RS4 sound, as it was old and not perfect. Now it comes with more samples, completely new, much longer starter and it's screaming even louder. Hope you like it.
[TUBE]<object width="560" height="340"><param name="movie" value="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/TUBE]
Filefront Download
Rapidshare Download
Mediafire Download
PS. Recommended ignition time is 2.725 sec. Although, you can set it to whatever you want, but I don't recommend the default value, it's definitely too short.
PS2. If you don't want the roar in the ignition, 0.66 sec is good value.
Wow, you are back. Nice to have you back!:thumbsup:
I see lots of work on this one as I can't notice any bug.:D
But if you want my opinion, it is a little too high pitched, so at high revs sounds a little bit weird.
Anyway congratz.:cheeky:
Yeah, agreed. That's why I'll still use the old one
Good to see you back! ;)
Nice sound. :) Old version it's for me much better.
So which is better for you? This or old one? Because I'm not sure from this.
RS4 is revving up to 8000 RPM, so it's got to be high pitched. Old was like it was cutting at 6000 RPM, in my opinion. I also think, that it sounds a bit better ingame than here. ;)
Awesome sound, fifo.
It will aso fit perfectly the 'little' R8.
One question though, what's the starter length to set in RS4 physics ? Original one is way too short.
  • 9 months later...
  • 9 months later...
