New version of TDU2 Texture Tools released!
v0.2 / November 29, 2011
> Texture Converter v0.6 (v0.6.3.9)
- Added Drag&Drop feature. (Multiple)
- Added progress-bar
- Optimized code
- Settings now are available.
> Texture Viewer v0.2 (v0.2.5.7)
- Added progress-bar.
Download link in the first post in this topic ;-)
Share this post
Link to post
Knyazev, Спасибо за програмку) Очень полезно, а то на просторах интернета была где-то прога для конверта из DDS в 2DB да ее уже и не найти нигде) + поставлю)
P.S Не стал себе парить мозг с английским, т.к проще написать на родном.
Share this post
Link to post
New version of Texture Tools released!
New fresh version: v0.3 with new name!
v0.3 / December 17, 2011
> Texture Converter v0.7 (v0.7.4.3)
- Added Drag&Drop feature in tab "Single file".
- Added startup splash-screen.
- Added one new option in settings.
- Corrected texts in some places.
- Tool renamed. New name is TDUMT II - Texture Converter.
> Texture Viewer v0.3 (v0.3.6.9)
- Added feature: Save 2DB File As... DDS, TGA, PNG, TIF or BMP.
- Tool renamed. New name is TDUMT II - Texture Viewer.
Share this post
Link to post
Hello Knyazev!
I working with many times your tool, and i found some bugs:
- wrong header (the texture name sometimes is wrong - maybe if i build texture from scratch (the header' texture and filename must be qual) )
- unnecessary footer (2db bitmaps don't use REAL block... but my be i wrong)
Share this post
Link to post
