  • 3
Question
  • Answers 2.4k
Top Posters For This Question
Popular Posts
You asked why you couldn't see the vehicles in the Platinum thread, which i told you that was an issue with bigbnk not being activated. You then proceeded and told me, via PM, that you have it activat
Features FreeRide's back online! New back-end features (such as time synchronisation) New client features (key shortcut, launch options, ...) Fuel Mode Modding enhan
FIXED IT!  I REPAIRED ALL OF MY REDIST VERSION (2013 TO 2017) AND NOW PROJECT PARADISE IS WORKING
Posted Images
  • 0
On 1/21/2017 at 4:43 AM, BlacknedAdElino said:
where are the gas stations ?
On 11/29/2014 at 10:06 AM, DartGT said:
has anyone petrol stations map?
On 11/10/2014 at 8:28 PM, Rassva said:
I usually bookmark the gas stations.
Here is the island map with stations. More images here. You can also open file C:\Users\YOURNAME\Documents\Test Drive Unlimited\savegame\YOURUSERNAME\bookmark\bookmark.txt and paste following block to the new line, before the last line containing single quote ('). Then you should be able to use bookmarks tab ingame and teleport to the stations.
"Wahiawa" 0 25012.59 264.77 26393.41 -0.915 -0.001 0.403 427897213
"Sand Island" 1 41935.16 1.89 47188.08 -0.858 0.003 -0.513 431313016
"Pearl Harbor" 2 34724.78 1.77 41195.74 -0.687 0.002 0.726 427918516
"Kapalama" 3 43968.45 43.50 44829.95 -0.653 0.021 -0.757 427927939
"Kaimuki" 4 48671.30 29.59 49335.75 -0.921 -0.055 -0.387 427935640
"Kuliouou" 5 57301.94 1.84 48773.56 0.040 0.000 -0.999 434922890
"Waimanalo" 6 57405.21 12.80 42719.71 -0.921 0.008 0.390 427921704
"Heeia" 7 47349.82 10.28 33397.70 0.516 0.015 -0.856 434920627
Edited by postcd
Link to post
  • 0
Hi @Djey @Milli @all , the right order of installation is like this?
TDU1
1.66A patch
no-dvd patch (replaces original .exe)
Project paradise
Platinum pack (official car megapack is absolete in this case and should not be installed?)
Platinum pack patch 1.1
Platinum pack patch 1.2...
Edited by postcd
Link to post
  • 0
TDU1
1.66A patch
Project paradise
You only need TDU (basic install) > Platinum > Platinum 1.12 update
Link to post
  • 0
so i have tdu and i try play online but it stuck at connecting to test drive server and then my game stop responding AKA crash i tried to reinstall the game and i even try without any mod but still no luck any suggestion? im using 1.66a version
Edited by yeetnob123
Link to post
  • 0
1 hour ago, yeetnob123 said:
connecting to testdrive server - unable to connect: try to delete TDU from Windows firewall and any other firewall. If that does not help, try to add it (paradise launcher, not original .exe) again among allowed firewall apps, try temporarily disabling firewall.  Think someone also recommend using VPN (use one which allows opening port - 8889). Inform what helped/if helped.
Edited by postcd
Link to post
  • 0
在 2020/10/12 在 PM6點11分, yeetnob123說:
I have the same issue here, I wonder if something is broken in my game files or its just an internet problem
Link to post
  • 0
So i use Project Paradise to get windowed mode (and 'unlock settings') to be able to get a windowed 1600x900 display within my 1920x1080 screen ( i have monitoring tools and recording software taking up the other space outside the 1600x900 TDU window).
Is there anyway to get the Project Paradise launch window (for when you click 'Start') to open at a set resolution? It opens the TDU game screen in a window that looks about 1024x768 (basically pretty small) and i have to stretch it to make it bigger (and hope i can hit 1600x900 exactly!).
It's rather cumbersome and not related to the resolution choice you make in the game menu. Now many games have a config file of some description where you can enter things like launch window resolution etc (Bethesda games have .ini files for this for example) and i wondered if anyone knew where that might be for the window Project Paradise launches after clicking start? Or is there another trick i could maybe use to get the windowed screen of TDU (it is the modded Platinum version) to always start at exactly 1600x900 and not the small screen i have to stretch and fiddle around with to hit an actual 1600x900 sized window?
The system i currently use is to launch another windowed game that DOES give an exact 1600x900 windowed screen, then launch TDU (via Project Paradise) and use the windows key to get on the desktop to click-drag the TDU game screen to match the other game underneath. Then i exit the other game, record a few seconds of footage (using Dxtory) then check the recorded footage is actually 1600x900 and not for example 1598x903 etc.
There must be a way to force the initial window that Project Paradise launches to be exactly 1600x900 (or another resolution of choice etc)?
Link to post
  • 0
Just to show the issue here is a pic of how the game launches using Project Paradise launcher, in terms of the game window size (even if the game resolution is set to 1600x900 in the game settings).
My desktop is 1920x1080. The game in the background is Brigador and that launches as a 1600x900 window. Then when i click 'Start' in the Project Paradise launcher i get that game window for TDU which i guess is about 1024x768 or something like that.
I then have to use the windows key to get out the TDU game window and fiddle around and stretch the TDU launch screen so it fits exactly to match that background Brigador game (1600x900). Then i quit that Brigador game and to be 100% sure i'm not a few pixels out i need to record a few seconds of footage, and maybe further adjust the TDU screen until it is perfectly 1600x900.
I'm looking for a way to launch TDU from the Project Paradise Launcher so that initial TDU screen is 1600x900 (so it launches like that Brigador screen) and not the default window you see in the screenshot. I hope this is more clear now 🙂
Edited by ZG264
Link to post
Answer this question...
Announcements
